Adding Your First IRC Network
IRC networks are added through the Networks area of the dashboard.
Current dashboard presets
Presets fill the common connection details, but you can review and edit them before adding the network.
Network name
The dashboard network name becomes part of your BNC login format.
Use a clear and unique name such as:
Do not create duplicate network names within the same account.
- Sign in to the dashboard.
- Open Networks.
- Choose a network preset or custom setup.
- Enter a unique dashboard network name.
- Review the IRC server hostname.
- Select the correct port.
- Enable or disable SSL/TLS as required.
- Enter your preferred IRC nickname.
- Submit the form once.
- Allow the dashboard to complete the setup.
Libera.Chat — irc.libera.chat — 6697 — TLS
OFTC — irc.oftc.net — 6697 — TLS
DALnet — irc.dal.net — 6697 — TLS
Undernet — irc6.undernet.org — 6667 — Non-TLS
QuakeNet — irc6.quakenet.org — 6667 — Non-TLS
IRCnet — irc.ircnet.com — 6667 — Non-TLS
Network name
Libera
DALnet
Undernet
