Guide Connecting With HexChat
Create a new HexChat network entry for the Eggy BNC connection.
Use:
Network name: Eggy BNC
Server: bnc.eggy.net/5000
Server password: Username/Network:Password
Depending on the HexChat version, SSL/TLS may appear as:
  • Use SSL for all servers.
  • Use TLS.
  • SSL connection.
Enable the available encrypted-connection option.
Password format
Enter the complete value in the server-password field:
Do not enter only the account password.
Multiple IRC networks
Create a separate HexChat network entry for each dashboard network.
Example:
Eggy BNC — Libera
Eggy BNC — DALnet
Eggy BNC — QuakeNet
Each entry connects to:
bnc.eggy.net
Port 5000
SSL/TLS enabled
Only the network name inside the server password changes.
If authentication fails
Check:
  • Username capitalisation.
  • Dashboard network-name capitalisation.
  • The colon before the password.
  • Whether HexChat saved an old password.
