Guide Connecting With mIRC
The quickest way to connect through mIRC is to use the command generated by the dashboard.
A typical command is:
/server -m bnc.eggy.net +5000 Username/Network:<password>
Replace:
  • Username with your exact BNC username.
  • Network with the dashboard network name.
  • <password> with your current BNC password.
Example format:
/server -m bnc.eggy.net +5000 ExampleUser/DALnet:<password>
Why +5000 is used
The plus sign tells mIRC to use SSL/TLS.
Correct:
+5000
Incorrect:
5000
Using plain port 5000 without TLS may result in an SSL error or immediate disconnection.
Opening more than one network
The -m switch opens the connection in a new mIRC server window.
This allows you to connect separately to each network stored on your BNC account.
Use the separate dashboard command generated for each network.
Never share a completed mIRC command because it contains your password.
