Connection Troubleshooting Checklist
Use this checklist before opening a support thread.
Your IRC client cannot connect to the BNC
Check:
The BNC connects but the external IRC network is offline
Check:
Web Chat will not launch
Check:
Do not repeatedly submit actions
Wait for the current add, reconnect, vHost or Web Chat request to finish before submitting another one.
Check:
- Server is
bnc.eggy.net. - Port is
5000. - SSL/TLS is enabled.
- The password uses
Username/Network:Password. - Username capitalisation is correct.
- The dashboard network name is correct.
- The saved password is current.
Check:
- The IRC server stored in the dashboard.
- The external server port.
- The external network SSL/TLS setting.
- Nickname validity.
- IPv4 or IPv6 compatibility.
- The exact external IRC network error.
Check:
- Web Chat was launched from the dashboard.
- The network exists on your account.
- The browser did not block the new tab.
- JavaScript is enabled.
- The entered BNC password is current.
