Guide Current IRC Network Presets
The dashboard provides presets for several commonly used IRC networks.
The current preset values are:
Libera.Chat
Server: irc.libera.chat
Port: 6697
OFTC
Server: irc.oftc.net
Port: 6697
DALnet
Server: irc.dal.net
Port: 6697
Undernet
Server: irc6.undernet.org
Port: 6667
SSL/TLS: Disabled
QuakeNet
Server: irc6.quakenet.org
Port: 6667
SSL/TLS: Disabled
IRCnet
Server: irc.ircnet.com
Port: 6667
SSL/TLS: Disabled
Presets are editable
Selecting a preset fills the common connection details.
Before adding the network, you can review or change:
  • Dashboard network name.
  • IRC server hostname.
  • Port.
  • SSL/TLS setting.
  • IRC nickname.
Only change a preset when you know that the replacement server and port are supported by the IRC network.
Using an incorrect encryption setting can cause immediate disconnections, TLS errors or connection timeouts.
