Guide SSL/TLS and Port 5000 Troubleshooting
Eggy BNC expects an encrypted client connection on port 5000.
In IRC clients that use a plus sign to indicate SSL/TLS, connect using:
/server -m bnc.eggy.net +5000 username/Network:password
Common symptoms of an incorrect TLS setting
You may see:
  • Connection reset.
  • Connection aborted.
  • SSL handshake failed.
  • The remote host closed the connection.
  • An immediate disconnect after connecting.
  • A timeout despite the server being online.
Checks to perform
  1. Confirm the server is bnc.eggy.net.
  2. Confirm the port is 5000.
  3. Enable SSL/TLS in the IRC client.
  4. Use +5000 where the client supports plus-prefixed SSL ports.
  5. Confirm the client is not forcing a plain-text connection.
  6. Copy the command directly from the dashboard.
Client settings
Some IRC clients use a checkbox instead of a plus sign.
In that case configure:
Address: bnc.eggy.net
Do not disable certificate checking merely to work around an unrelated username, password or network error.
An SSL/TLS connection only establishes the secure link to Eggy BNC. Your username, network name and password must still be correct.
