Using Several IRC Networks on Mobile
Each dashboard network requires its own BNC connection identity.
All mobile-client entries use:
The password field changes according to the network:
Recommended naming
Save entries with clear labels:
Changing only the nickname does not select a different dashboard network.
The network is selected by the value after the slash:
A mobile application may display each connection in a separate tab, server list or network section.
Server: bnc.eggy.net
ExampleUser/Libera:Password
ExampleUser/DALnet:Password
ExampleUser/OFTC:Password
Recommended naming
- Eggy BNC — Libera.
- Eggy BNC — DALnet.
- Eggy BNC — OFTC.
Username/Network
